p0500 vehicle speed sensor
2001 TOYOTA SIENNA
1,934,398 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
FRANK URBACK
Hello, my name is Frank. I took my van for emissions and it failed p0500 code. Which is a speed sensor. I changed the sensor twice and it still failed. How many speed sensors does the van have? The cruise control is not working, odometer is not working.
Nov 10, 2018 at 8:21 PM
Hell Frank,
There is only transmission speeds sensor they call it a direct clutch sensor. Here is a guide to help you check the connection between the sensor and the PCM. If the connections are good replace the PCM with a used/rebuilt unit.
Check out the diagrams (below). Please run this test and get back to us.
Nov 12, 2018 at 1:04 PM
