My car has codes P0492 P0443 p140A P0444
2007 BMW 328
99,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
EVERYCAR_BIMMER
  • 5 POSTS
My car is showing several codes P0492 P0443 p140A P0444 and I do not know what is wrong. My car does not seem to struggle nor make weird noises. I made sure the gas cap was closed and do not know what parts to purchase to erase the codes. Please help.
Oct 23, 2016 at 9:54 PM
AL514
  • 5,462 POSTS
First code P0492 Secondary Air Injection System Insufficient Flow (Bank2)
P0443 Evap Purge Valve Circuit
P140A Secondary Air Injection System Insufficient Total Flow (bank1 and bank2)
P0444 Evap Emission System Purge Control Valve Circuit Open
I think you might want to take this on to a shop, These are EGR and fuel tank vapor EVAP codes. There may be a wiring problem or problems with the valves or controllers themselves. This system has to be diagnosed by someone who knows and has the proper scan tools to test everything. You cannot just throw parts at this and hope to fix it. They are emissions related also so you wont be able to pass inspection with it like this unfortunately.
Oct 24, 2016 at 8:31 AM
EVERYCAR_BIMMER
  • 5 POSTS
Thank you for the quick response. I recently replaced the crankshaft sensor and was wondering if this problem was cause if I left a sensor disconnected (I don't think I did) or is it two completely different areas?? The car now only reads P0444 and P0492. Today, I turned the car on and excessive white smoke was coming out of the exhaust and I quickly turned the car off. I turned the car back on and no smoke was coming out so I proceeded with my regular schedule. What does the excessive white smoke mean? The car was not overheating. Should I have left the car on when smoking? Should I stop driving the car immediately to avoid major damage?
Oct 25, 2016 at 5:32 PM
AL514
  • 5,462 POSTS
For the P0444 first try tightening your gas cap, and see if that code comes back, it has to do with the Canister purge system. It takes vapor from the gas tank and sends it into the intake manifold to burn, but if theres any leaks it will set EVAP codes like this. As for the P0492, you can start checking vacuum lines, this system runs an air pump, check valve for the pump, and a solenoid and a lot of vacuum lines to all these parts. On the left side of the engine compartment next to the valve cover is the pump(checking this pump the engine must be completely cold), it looks like a round cover with a big rubber pressure line coming off of it. you can take this line off and should have air being forced out of it, unfortunately all the vacuum lines for the system run underneath and behind the intake manifold and are very hard to get to. As for the white smoke, if it went away when the car warmed up, just keep an eye on it, white smoke is usually just water vapor, unless its thick and excessive. That could be a bad head gasket or anything allowing coolant into the combustion chamber. For the other codes and their systems you may want to have a technician look at it. As it can be quite a few different problems.
Oct 26, 2016 at 7:02 AM
