P0491 Secondary Air Injection System Insufficient Flow. Stumped.
My VW CC 2010 is having a check engine light with the code P0491 which means the pressure sensor is not detecting enough air being pumped from the intake into the exhaust.
I have already:
Replaced the Secondary Air Pump
Replaced the Combination Valve (did not replace the gasket)
Replaced the O rings
Replaced the pressure sensor
Replaced engine air filter
Checked for leaks
Checked to see if the exhaust hole in the manifold was clogged
Full car details are listed above.
Engine: 2.0L TSI CBFA
I have already:
Checked for leaks
Oct 11, 2020 at 6:27 PM
