Which engine do you have, are you sure you have the right sensor? With the four cylinder there is no question but the v6 has two secondary sensors. I don't think it is the sensor if you have changed it twice and it is not a circuit failure code, so I don't think it is a connection problem. Here are the main reasons for the code:
Faulty Catalytic Converter: The most common cause of a P0421 code is a failing catalytic converter.
Can I ask if you have an exhaust leak? This will cause the problem, if there are no exhaust leaks, I would replace the catalytic converter. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/catalytic-converter-replacement
Sep 13, 2023 at 12:08 PM
