Greetings, you amazing mechanics!
The check engine light came on in the VSC light started blinking. My scanner showed P0420 code relating to the catalytic converter. After doing a little research, I saw that it could be multiple different reasons, and may not actually be the catalytic converter failing. This is where I defer to your amazing mechanic expertise! How would you go about diagnosing the issue?
Thank you in advance!!!
Jan 8, 2026 at 11:02 AM
