Check Engine light on with codes P0393 and C1201?
2008 LEXUS IS 250
250,000 MILES • 2.5L • 6 CYL • AUTOMATIC
JESSE BERMUDEZ
I received this car with multiple dash lights on, Check VSC, ABS, CEL. First, I tried tackling the check engine light which pulls code P0393 cam position sensor bank 2 sensor B circuit high. The connector was replaced prior to me receiving it, and I put in a new sensor, and I still get the same code.
Aug 13, 2022 at 10:32 PM
Bank 2 exhaust camshaft position sensor, have you checked voltage to it? Is it more than 4.7V? Is the new sensor flush and seated properly?
As far as the other code, I need you to start a new thread related specifically to it. We try to keep the threads specific to one topic to help others better. I hope you understand.
When you do, indicate if the vehicle has VDIM (vehicle dynamics integrated management) or not.
Here is the link to start a new post:
Aug 14, 2022 at 9:29 PM
