Code P0344
2003 DODGE NEON
296,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CANNON1349
  • 861 POSTS
A customer brought in this vehicle for a new catalytic converter to get rid of the P0420 code.
After installing a new catalytic converter I went to clear the codes, which cleared successfully, but the following codes are still there:
P0016 Crank-Cam Position Correlation
P0344 Camshaft Position Sensor "A" Circuit Intermittent (Bank 1 or Single Sensor)
The engine does run a little rough, and sometimes will not start without giving it a little gas. Also when idling if I rev the engine to 2,000 rpm's a little rattle comes up and will not accelerate more.
I am assuming the P0344 wiring issue is causing the P0016 code, but can that be possible? Can this wiring fault cause the engine to run rough and possible out of time like this?
Aug 19, 2018 at 9:40 AM
Good afternoon.
Yes it can. Inspect the harness very carefully. At the cam sensor, peel back the covering on the harness about six inches. That is a common place for the failure.
Do the same to the crank sensor as well.
Make sure you have the 5 volt reference signal to each sensor as well.
P0344
Descriptor
Camshaft Position Sensor Intermittent
Probable Causes
5 Volt Supply Circuit Open or Shorted to Ground
Camshaft Position (CMP) Sensor
Camshaft Position (CMP) Sensor Signal Circuit Open
Camshaft Position (CMP) Sensor Signal Circuit Short to (K7) 5 Volts
Camshaft Position (CMP) Sensor Signal Circuit Short to Ground
Camshaft Position (CMP) Sensor Signal Circuit Shorted to B+
Crankshaft Position (CKP) Sensor Signal
Good Trip Counter Equal to Zero
Powertrain Control Module (PCM)
Tone Wheel/Pulse Ring
Wiring Harness
Aug 19, 2018 at 1:27 PM
