Check engine light is on and the spark plug in sixth cylinder is wet. when EPC faults appeare and Engine is fluctiating. Code: P0306.
Aug 4, 2016 at 10:57 AM
WRENCHTECH
CERTIFIED EXPERT
I would first check the compression on that cylinder to make sure the problem is not mechanical. If compression is good, I would suspect a problem with the plug or bad coil.
