So, I got into my car in the parking garage after work today and it had a rough start with the check engine light flashing and the VSA light also came on. I scanned it and the above code showed up. I replaced my spark plugs and ignition coils last year in September, and I did my most recent oil change in the beginning of September this year. I’ve had a similar problem a couple years ago with similar codes and low oil is what caused it. I went to a nearby AutoZone and bought a quart of oil, topped it off and also disconnected and reconnected the cylinder 4 coil. This stopped the flashing check engine light and rough engine idle, but the same code remains. What can this be?
Nov 13, 2024 at 5:17 PM
