Code P0302
1997 TOYOTA COROLLA
153,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JAYKING555
Getting a misfire on cylinder 2, but i replaced wires distributor cap and rotor and spark plugs, still a misfire. i don't know what to do anymore. fuel system is a good working order.
Jan 31, 2020 at 8:15 AM
SCGRANTURISMO
  • 4,897 POSTS
If the fuel system is working and you have just replaced the ignition system I would recommend doing a compression test on your vehicle. An engine only needs three things to run, Fuel, spark[delivered at the proper time], and compression. Here is a link below explaining how to do the test:
Please go through this guide and get back to us with what you find out.
Thanks,
Alex
2CarPros
Jan 31, 2020 at 11:25 AM
