So, I have replaced the spark plugs, wires, fuel filter, and now I was thinking about replacing an injector because I did the stethoscope test, and one wasn’t clicking as loudly as the others. It was clicking though. However, when I turn it on, I’ve realized I do have symptoms that could point to the EGR valve but I’m not totally sure. I’m also wondering if it’s obviously something else that I don’t see or know. When I start the car, there is a rough idle, it struggles for power right after ignition and is tougher than it is after giving it a little gas. There is also a bit of grey or white smoke from the exhaust at ignition, but it stops. I did notice a slight gas smell as well but that could have also been when I was disconnecting hoses to get to the bolts to remove the exhaust manifold to get to the fuel rail and eventually replace the injector I was looking at. I also have a newer GM electronic EGR valve. so, I’m wondering if I can test if this one is bad before buying a new one and testing it that way or where should I be focusing?
Mar 27, 2022 at 4:43 PM
