Codes P0300, P0301, and P306?
1997 TOYOTA 4RUNNER
280,000 MILES • 3.4L • V6 • 4WD • MANUAL
CHIEF1234
Hello everyone, my vehicle has been throwing these codes. I've replaced the plugs and coils; I don't smell any fuel or anything and I don't know what to check after this. Any ideas?
Dec 21, 2022 at 4:39 PM
It could be a couple of things. Since you have already replaced the plugs and coils, you may want to check the fuel pressure to see if it is weak.
Here is a link that explains how it's done:
If the same codes return after clearing them, you may want to consider checking engine compression. Low compression in a cylinder or cylinders can also cause a misfire.
Here is a link that explains how that is done:
Both of these tests require a pressure gauge. Most parts stores will lend one to you free of charge.
Let me know your thoughts. Also, if you have other questions, let me know.
joe
Dec 21, 2022 at 10:17 PM
