Hey guys just following up! I am still working on this same issue now for four years. Of course the van sits more than we drive it due to how it runs.
I replaced the coil packs this last summer and no changes. I did a smoke test tonight just to make sure of no vacuum leaks even though my vacuum gauge did not move an inch 16/18 psi on vacuum. No need to do a compression test with gauge not fluctuating. I have not done a fuel pressure test yet. This van does not start a rough idle until it warms up! I am about to pull the rest of my hair out on this. Could it be a bad timing chain? Should I still do a compression test? Bad PCM? I will never buy another GM V-6 product again. They are junk! Thanks
Nov 6, 2017 at 5:58 PM
