intermittent code P0300
2007 CHEVROLET SUBURBAN
220,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
07BURBLTZ
  • 5 POSTS
I am having intermittent p0300. Only really noticeable at idle and like I said it's intermittent. To the point the code will clear after enough ignition cycles. I have already replaced all the lifters, cam was in good condition, the VLOM, oil pressure sensor, MAP sensor, injector on 6, plugs, wires, cleaned throttle body, cleaned the MAF, had the heads gone over and milled .03, the wiring loom/harness is in decent shape. I will also get a p0306. (the reason I replaced injector) to no avail. The service stabilitrak, and service traction control will kick on at idle. If I raise the RPMs and hold it it will go away with no check engine some times. If I don't raise RPMs it will begin to miss harder to the point the check engine light flashes. Oil pressure is decent but could be a little better, never lower than 30, never higher than 58 or so. What should I load into the parts cannon next?!?
Feb 2, 2021 at 5:10 PM
It sounds like you have done a lot of work already. I do have a question. Anytime I have a random misfire and a rough idle, I suspect an engine vacuum leak. Have you checked all over for leaks? Also, I realize you did a lot of work, but is compression within the manufacturer's specs? If you have a live data scan tool, can you tell me if the short term fuel trims?
Take a look through this link. It explains how to locate a vacuum leak.
Let me know if you have already checked that or if you have other questions.
Take care and God Bless,
Feb 2, 2021 at 7:02 PM
07BURBLTZ
  • 5 POSTS
I have not checked with a gauge, but I have sprayed the intake/head mating surfaces with brake cleaner. I will see if I can get it in tomorrow to check with a gauge. What is spec? It's an lc9 with vacuum assisted brake booster.
Feb 2, 2021 at 7:14 PM
At idle, you should have between 17 hg and 21 hg. Let me know what you find. Also, if you have a live data scan tool, let's take a look at the short term fuel trims. That can tell us a lot. We can determine if the fuel mixture is lean or rich based on it.
Take care and God bless,
Feb 2, 2021 at 7:30 PM
07BURBLTZ
  • 5 POSTS
Thanks! I will see if I can get a vacuum gauge and I'll scan it and let you know.
Feb 2, 2021 at 7:32 PM
Sounds like a plan. I'll watch for your reply.
Feb 2, 2021 at 7:50 PM
07BURBLTZ
  • 5 POSTS
Both Ltft and stft are negative. I was pouring over the scan tool and bank 2 was worse. But I noticed my ethanol content was reading 30% after I filled it from empty with premium. Thought it odd the percentage was so high. I also reset trims after resetting ethanol content. Also this issue has been going on for about a year. Gas type/ethanol content/octane hasn't made a difference.
Feb 5, 2021 at 4:56 PM
What were the actual fuel trims? I need to know how far in the negative they were.
Feb 5, 2021 at 8:13 PM
07BURBLTZ
  • 5 POSTS
The Ltft was -15 on bank 1 -22 on bank 2, the stft -2 on bank 1 and 0 on bank 2.
Feb 6, 2021 at 4:36 AM
Since the trims are negative, that indicates the computer is trying to reduce the fuel to the engine. Have you checked fuel pressure?
Feb 6, 2021 at 5:05 PM
