Code P0300
2005 CHEVROLET AVEO
48,000 MILES • 4 CYL • AUTOMATIC
XXCOOPER1XX
  • 6 POSTS
I got a P0300 code on my car. It is a 4 door hatchback. My check engine light blinks along with the Hold button. In the past 6 months i have replaced the following:
Battery
Battery Terminals
Fuel injection cleaner when filling-up, a full tank of gas
Engine coolant thermostat
Camshaft position sensor
Ignition coil pack
Spark plugs and wires
Fuel Pump Relay Switch
Air cleaner intake hose with sensor
EGR valve with gasket
Serpentine Belt
Fuel Pump
Fuel injectors
Throttle position sensor and you cleaned the throttle body
Aug 2, 2019 at 10:26 PM
Welcome to 2CarPros.
Many things can cause a random misfire. Is the P0300 the only code you get? If so, have you confirmed fuel pressure to be within spec? Also, have you checked for engine vacuum leaks?
If you haven't done that, I would start there. Also, keep in mind that fuel pressure ( too high or low) can cause this. Here are the manufacturer's specs for pressure.
Fuel Pressure (Key ON, Engine OFF) .................... 380-427 kPa (55-62 psi)
Check that and let me know what you find. If you need a gauge, most parts stores will lend or rent one to you.
Aug 2, 2019 at 10:53 PM
XXCOOPER1XX
  • 6 POSTS
I've done a lot of work on my car the past 6 months and usually my check engine light blinks and my hold light blinks when I'm on the highway going 60 mph. Last night i got my friend to install a throttle position sensor, and fuel injectors in my car and now its acting up bad. It's fluttering, loss of acceleration, ect. The check engine light blinks and the Hold button blinks as soon as a start my car up. I took it to AutoZone and they got a P0300 code (which i wasn't surprised) but i also got the recommended fix that i need to relearn the crankshaft position procedure. I am going to the dealer Monday. My question is, should i replace the crankshaft before the dealer? Like disconnect the negative battery terminals, install the crankshaft myself in hopes it will go away? Or do you think the crankshaft is good but needs to be relearned?
Aug 5, 2019 at 11:34 AM (Merged)
Why was that suggestion made? A relearn is done after the sensor is replaced and I don't believe even replacing one on this vehicle calls for a relearn. Here are the directions for replacement of the crankshaft position sensor. Note at the end is where it indicates a relearn and none is mentioned.
As far as the crank sensor, here are a few links to help. The first explains what it does, the second explains symptoms, and the third shows in general how one is replaced.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Here are the directions specific to your vehicle:
___________________________
CRANKSHAFT POSITION (CKP) SENSOR REPLACEMENT
Crankshaft Position Sensor Replacement
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Service Precautions.
pic 1
1. Disconnect the negative battery cable.
2. Disconnect the crankshaft position (CKP) sensor electrical connector.
pic 2
3. Remove the CKP sensor bolt.
4. Remove the CKP sensor.
Installation Procedure
Notice: Refer to Fastener Notice in Service Precautions.
pic 3
1. Install the CKP sensor with the bolt.
Tighten
Tighten the CKP sensor bolt to 6.5 Nm (58 lb in).
pic 4
2. Connect the CKP sensor electrical connector.
3. Connect the negative battery cable.
__________________
I'm not saying it couldn't be the sensor, but since it got worse since it was repaired, I would start by checking to see if maybe something like a vacuum line was left off or something wasn't plugged in.
joe
XXCOOPER1XX
  • 6 POSTS
I've done all this work within the year:
Battery
Battery terminals
Ignition coil pack
Fuel pump
Fuel injectors ( I have put fuel injection cleaner on fuel fill- ups)
Fuel pump relay fuse
Serpentine belt
Throttle position sensor ( I have also cleaned the throttle body)
SCGRANTURISMO
  • 4,897 POSTS
Direct Trouble Code (DTC) P0300 is the DTC for a Random/Multiple Misfire. In the diagrams down below I have included the factory diagnostic troubleshooting guide for DTC P0300. I have also included the fuel pressure so you can check that as well. Another thing to consider, believe it or not, is the Engine Coolant Temperature Sensor (ECT), as this will effect the engine ignition timing, retarding it as the temperature goes up to keep the engine away from detonation. Also inspect the intake air duct, vacuum and EVAP lines for leaks, and especially around the intake manifold for vacuum leaks. This will also make your vehicle run bad. Also double check that the correct fuel injectors were installed. Please go through the guide and get back to us with what you able to find out.
Thanks,
Alex
2CarPros
