Cranks but will not start. Engine starts to run when spraying in starter fluid. Fuse and Relay in fuse box under hood are both good. Hit reset button on inertia switch - no help there. Put in new fuel filter. With fuel filter out, cranked engine, but no gas came out the opened up fuel line. Old fuel filter has some restriction.
Do I need a new fuel pump, or is there a problem with some module or circuitry?
Dec 8, 2015 at 6:51 AM
