Hey 04EXPLORER,
If you can find a way to get a read out from the fuel temperature sensor and give me the current value please. This would be very quick for someone with a scanner with live data.
The sensor in question is shown in the attached picture.
It states you need to remove part of the intake to replace the sensor but you may be able to unplug it without intake removal for testing.
If you can inspect and find the sensor, trace the wiring to see if there is any obvious damage. Areas where is can rub through or be pinched.
Let me know how you go locating the sensor and i can provide further diagrams if required.
Are you comfortable with wire testing?
Regards, Joe
Mar 18, 2019 at 12:05 PM
