Have an ongoing p0174 and p1151. I also have a buzz sound when depressing the accelerator pedal. I isolated it to the circuit in the power distribution box (INJ30 fuse). When removed the buzz stops . what all is on this circuit? is there a wiring diagram and pin out for everything on the INJ30 circuit ? Also the exhaust seems low output for pressure not sure if it's a possible plugged catalytic converter causing the p0174 lean code and low voltage 1151 for bank 2 the oxygen sensors on bank 1 and 2 upstream are new sensors. No vacuum leaks detected in system. Could the EVR cause the p0174 and P1151 ?
Oct 22, 2020 at 8:07 AM
