Got a system too rich bank 1 code. I changed the spark plugs and coil packs, changed the mass air flow sensor, changed MAP sensor, changed the 2 oxygen sensors, changed the fuel injectors, cleaned the throttle body. It still stutters and stalls out. I don't know how to perfectly do a vacuum leak test but I'm not even sure that's the problem, hence why I'm posting. Can you point me in the right direction?
Aug 29, 2021 at 6:25 PM
