Codes P0171, P0102, P0113, P0340
2007 TOYOTA COROLLA
183,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
07WHITECOROLLA
  • 8 POSTS
Hello, my car has four fault codes and I am trying to remove them. I bought the camshaft position sensor for the P0340 code and I will be installing that this Thursday when it arrives. The other three codes have been an ongoing problem and is becoming very frustrating. I have done several tests on the MAF wiring according to various sites online and it has come back with good results. I also replaced the MAF with an OEM Denso brand with no results. Is there a wiring diagram that I can look at or something because there has to be an issue with the wires since these codes will not go away? I started to peel back the the tape and the wires just seem to be never ending and it would really help if I knew where the ground was instead of trying to peel back all of the tape. I have had the car smoke tested for a vacuum leak as well and it does not have any. Spark plugs were recently replaced as well as the intake and valve cover gasket. Help!
Apr 24, 2018 at 11:08 PM
The system too lean problem can be caused by a weak fuel pump. here is a guide to help you get an idea of how to test the fuel pressure:
Here is a guide to help you check the engine wiring diagrams below:
Check out the diagrams (below).
Apr 26, 2018 at 5:02 PM
07WHITECOROLLA
  • 8 POSTS
Just replaced fuel pump and pressure is good. Did not fix my issue. I checked compression too and it was great.
Apr 26, 2018 at 6:41 PM
The fact that the camshaft position sensor code will not go away is telling me the camshaft must be in the worn time like a camshaft actuator is not working or worn out. I have seen where people change there oil and the actuator starts working again while other times it must be replaced at 183,000 miles this is big possibility. Below are diagrams to help you see what you are in for when doing the job. You should also install a new timing chain.
Below are diagrams to show you what you are in for when doing the job.
Apr 27, 2018 at 8:53 AM
07WHITECOROLLA
  • 8 POSTS
I am replacing the camshaft position sensor today to see if that code goes away but my real problem is the P0171, P0113, and P0102. That is why I wanted to see where the ground is for the MAF sensor so I can check the connection as well as the other four wires too.
Apr 27, 2018 at 10:20 AM
07WHITECOROLLA
  • 8 POSTS
I installed a new ECT, and camshaft position sensor. I unwrapped the tape for the MAF wiring and sprayed parts cleaner on the grounds and the codes went away. The only code is the P0171 still and I cannot remove it. I took the PCV valve off and put my hand on it and it is sucking so it is working properly.
Apr 27, 2018 at 7:59 PM
We are getting closer. Do you have any exhaust leaks? Because that will make the system run lean. Here is a guide to help us with this problem:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Please run this test and get back to us.
Apr 28, 2018 at 9:00 AM
07WHITECOROLLA
  • 8 POSTS
No exhaust leaks, because the smoke test would have found it. I am thinking about replacing my vacuum purge valve switch and see what it does and then fuel injectors if I do not see a change.
Apr 28, 2018 at 9:52 AM
I have seen clogged injectors cause a lean code. If you replace them use the OEM or you will regret it. Sometimes they work sometimes they do not.
Apr 28, 2018 at 4:18 PM
07WHITECOROLLA
  • 8 POSTS
Okay, I ordered four Denso injectors which should be here by Friday. I will keep you posted. Thanks.
Apr 29, 2018 at 3:57 PM
Please let me know. :)
Apr 30, 2018 at 11:12 AM
JROCK14
  • 19 POSTS
Code gone and everything is works great! My fuel injectors had to of all been clogged or dirty.
May 2, 2018 at 8:20 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
May 3, 2018 at 9:58 AM
