P0171 code, cleaned MAF then got a p0174 temporarily?
2013 GMC SIERRA
86,350 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HSAYLOR0
P0171 code. Cleaned MAF then got a p0174 temporarily. Sprayed water at base of intake and no noticeable difference. Not sure where to go next. My basic scan tool said fuel pressure at idle was 44 psi. It is the 5.3 lc9 flex fuel engine. Sluggish take off and bad fuel economy. About 13MPG.
May 15, 2023 at 9:49 PM
The P0171 code specifically points to a lean condition
Since the cleaning fixed it for a while, I would replace the MAF sensor because once the sensor is too far gone cleaning it will not help to will also cause low power and gas mileage. Here is how to change out the sensor correctly. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
May 16, 2023 at 12:01 PM
HSAYLOR0
Sorry, the cleaning didn't fix it. It caused a second code, p0174, temporarily. I tried to load the scanner freeze frame to give you more info.
May 16, 2023 at 5:08 PM
By these readings I would replace check for vacuum and exhaust leaks and if there none replace the sensor. Also, you should check the fuel pressure, here are guides to help you:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Use this guide when the engine is cold only:
and
Key On Engine Off (KOEO): The fuel pressure should be approximately 60-66 PSI. (Pounds per square inch).
Key On Engine Running (KOER): The fuel pressure should be approximately 55-62 PSI.
You can rent the gauge at the local auto parts store for free or cheap. Please go over these guides and get back to us.
May 17, 2023 at 9:26 AM
