Code p0171?
2003 TOYOTA CAMRY
220 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PANACHET
engine low in power and the car vibrates when the car is in load.
Oct 5, 2022 at 2:43 AM
Code P0171 is for lean exhaust condition. This is common when the engine is misfiring, I would do a tune up with OEM spark plugs and then clear the codes. Also we can check for a vacuum leak, please follow this guide when the engine is cold only. I would also do the ignition coils which is common as well. Check out the guides below to see how the job is done.
and
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Check out the images (Below). Let us know what happens and please upload pictures or videos of the problem.
Recommended Spark Plugs: Denso MadeSK20R11 or NGK Made IFR6A11
Gap .................... 1.0 - 1.1 mm (0.039 - 0.043 in)
Torque .................... 19 Nm (14 lb-ft)
This guide can help walk you through the job:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Oct 5, 2022 at 3:52 PM
JIS001
  • 3,412 POSTS
Hello, I just wanted to jump in. P0171 is for running too lean. Posible problems are vacuum leaks, low fuel pressure, or faulty mass air flow. Can you provide a freeze frame to see when the light was triggered? If it is in idle then I would suspect a vacuum leak. If it set during cruising speeds, I would look at the mass air flow sensor as a possible fault.
Oct 7, 2022 at 10:12 PM
