I have a p0158. When I check the datastream on my scan tool it shows the downstream o2 sensor stuck at 1.27 volts. After a few minutes it starts to fluctuate between 1 volt and 1.27 volts. After that it will fluctuating, for example between .80 and .86 volts
It does not follow the upstream sensor at all.
Thank you
Thank you
Nov 1, 2018 at 10:52 AM
