Code p0133, O2 sensor bank 1 sensor 1 slow response?
2004 TOYOTA COROLLA
230,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
YAZIDAN
  • 133 POSTS
I have a p0133 code. O2 sensor bank1 sensor 1 slow response. What are the causes. where to start diagnosing?
Thank you
Apr 16, 2024 at 2:37 PM
The code indicates a slow response from the sensor. In most cases, the sensor itself is faulty and needs to be replaced.
However, I attached information below for you. It explains how the circuit works and the diagnostics specific to this code.
Let me know if this helps.
joe
See pics below.
Apr 16, 2024 at 8:14 PM
Here is the location of the bank 1 sensor 1 which could be telling you the primary catalytic converter might be going bad, clogged. Check out the images (below). Please let us know what happens.
Apr 16, 2024 at 8:55 PM
YAZIDAN
  • 133 POSTS
The code is intermittent does this change in diagnosis?
Apr 17, 2024 at 7:36 PM
Did you swap the sensor out? If so and the codes is still there I would still check the condition of the catalytic converter. The oxygen sensor is not switching because the exhaust cannot flow correctly.
Apr 18, 2024 at 10:10 AM
YAZIDAN
  • 133 POSTS
no, I did not replace the oxygen sensor. also, what I noticed is that the MAF sensor g/s at idle is low 1.4 g/s and fuel trim at 7%.
Apr 18, 2024 at 12:17 PM
That might be normal. can I ask what you are comparing the MAF sensor reads too? Also is the fuel trim long or short? You can try a MAF sensor to see if it helps, also can I ask how the power output of the engine is, low or normal?
Apr 19, 2024 at 9:44 AM
YAZIDAN
  • 133 POSTS
sorry for the delayed response.
1.what i heard MAF sensor reading at idle should be more than the engine displacement.so it should be more than 1.8g/s.
2. total fuel trim
3.engine power is good
Apr 24, 2024 at 4:29 PM
Okay, I would replace the oxygen sensor and then clear the codes to see what happens.
Apr 25, 2024 at 9:52 AM
