Taking too long to get to operating temperature, code P0128
2005 PONTIAC G6
106,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ALEXTTT
  • 59 POSTS
For the last couple of days my car has not been getting to the normal operation temperature it been getting to 160 degrees and usually it’s at 200. I got a check engine code for P0128 saying the car is taking too long to heat up. I’m planning to replace the thermostat tomorrow. Today I went to check the upper hose where the thermostat is and it was extremely hot to touch.
Nov 9, 2020 at 6:27 PM
The hose being hot is normal if the engine was just turned off or running. As far as the code, the thermostat is the likely cause. If the engine doesn't warm up fast enough because the thermostat isn't allowing it to, it increases the emissions put out by the vehicle which can result in the code you mentioned. So what you have suggested makes sense to repair the issue.
__________
Here is a link you may find helpful. It explains in general how a thermostat is replaced.
__________
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
__________
2005 Pontiac G6 V6-3.5L VIN 8
Procedures
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Procedures
PROCEDURES
Thermostat Replacement
Tools Required
^ J38185 Hose Clamp Pliers
Removal Procedure
pic 1
1. Remove the air cleaner intake duct.
2. Partially drain the cooling system.
3. Use the J38185 in order to reposition the hose clamp from the thermostat housing.
4. Remove the radiator inlet hose from the thermostat housing.
5. Remove the thermostat housing bolts.
pic 2
6. Remove the thermostat housing.
pic 3
7. Remove the thermostat.
8. Clean and inspect the thermostat housing gasket mating surfaces.
Installation Procedure
pic 4
1. Install the thermostat.
pic 5
2. Install the thermostat housing.
pic 6
3. Notice: Refer to Fastener Notice in Service Precautions.
Install the thermostat housing bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
4. Install the radiator inlet hose to the thermostat housing.
5. Use the J38185 in order to reposition and install the hose clamp to the thermostat housing.
6. Install the air cleaner intake duct.
7. Fill the cooling system.
________________________
When you refill the system, here are the directions for bleeding the air from the cooling system. Again, the attached pics correlate with the directions.
Fill Procedure
1. Notice: The procedure below must be followed. Improper coolant level could result in a low or high coolant level condition, causing engine damage.
Install the engine block left coolant drain plug.
2. Close the radiator drain plug.
3. Lower the vehicle.
4. Vehicle should be level.
pic 7
5. Add a mixture of 50/50 DEX-COOL(R) antifreeze and clean drinkable water until the level stabilizes at the weld seam on the surge tank.
pic 8
6. Unscrew the coolant bleed screw on the engine until coolant comes out of the bleed screw.
7. Close the bleed screw.
8. Add coolant until the level stabilizes at the weld seam on the surge tank.
pic 9
9. Install the surge tank cap.
10. Important: DO NOT exceed 2,200 RPM.
Start the engine and run at 2,000 RPM until the engine cooling fans turn ON.
11. Remove the surge tank cap.
12. Refill to the weld seam on the surge tank.
13. Important: Coolant should be at the full cold mark when the system cools.
14. Inspect the concentration of the engine coolant using J26568.
15. Rinse away any excess coolant from the engine and the engine compartment.
Make sure if the vehicle still has the original DexCool coolant not to mix it with the traditional Green coolant. Either use DexCool or look for a universal coolant that can be used with DexCool.
I hope this helps. Let me know if you have other questions.
Nov 9, 2020 at 7:53 PM
ALEXTTT
  • 59 POSTS
Thank you for replying back. Also I been using 100% Dex-cool concentrated. What are some problems I have encounter if I don’t add water to the concentrated antifreeze?
Nov 9, 2020 at 8:49 PM
It won't cause any problems. However, when you use a 50/50 mix, it actually makes the coolant stronger. For example, it will lower the freezing point as well as raise the boiling point. I don't know where you live or if that is even a concern for you.
Let me know if you have other questions or need help.
Nov 9, 2020 at 9:07 PM
ALEXTTT
  • 59 POSTS
That’s good to know. Also the heater takes at least 20 minutes to work. But I’m sure that’s cause of the thermostat.
Nov 9, 2020 at 9:47 PM
Hi:,
In most cases, that will cause the heater to be less effective. If you can, let me know how it turns out for you.
If you have questions, feel free to ask.
Nov 10, 2020 at 12:21 PM
ALEXTTT
  • 59 POSTS
So during this process I disconnected the battery cause a evap code came on for the canister purge valve so now the it’s ticking a lot. So I disconnected the battery and now it won’t start all lights turn in radio is good. I went to AutoZone and had the battery tested and it’s good. I believe the starter maybe be bad. I was reading a forum where the starter goes bad over time because the exhaust pipe is so close to the starter.
Nov 10, 2020 at 12:49 PM
Do me a favor. Have a helper turn the key to the start position while you record what is happening under the hood. Also, take a look through this link and let me know if it helps. I doubt the starter went bad, but anything is possible.
https://www.2carpros.com/articles/starter-not-working-repair
Make sure the battery terminals are clean and tight and confirm a fuse didn't blow when you disconnected the battery. Also, make sure it is fully in park or neutral when trying to start it.
See the attached pics to help locate the fuses I need checked. In addition to checking the fuses' conditions, make sure there is power to them and out from them. Here is a link you may find helpful:
Let me know what you find.
Nov 10, 2020 at 1:04 PM
ALEXTTT
  • 59 POSTS
I’ll check those. Also on my radio it says locked. I figure it has to do something with the anti lock system.
Nov 10, 2020 at 2:26 PM
The radio is locked? That could be due to disconnecting the battery.
Have you had success in locating the issues?
Nov 11, 2020 at 2:05 PM
ALEXTTT
  • 59 POSTS
I had it towed to the dealership and they said the battery has low voltage, so they are going to replace the battery. I find it weird before I took the battery out it started up fine and then once I reconnected it the battery wouldn’t allow it to start.
Nov 11, 2020 at 2:52 PM
That is odd. Actually, it doesn't make sense.
If you can, please let me know what they tell you. Also, if you have questions or need help, let me know.
Nov 11, 2020 at 2:54 PM
ALEXTTT
  • 59 POSTS
Alright, so I got the car back and it’s running a lot better. Changing the thermostat fixed my P0128 problem.
Nov 12, 2020 at 3:39 PM
Thanks for letting me know. It's crazy anymore the things that cause problems. Who would think the engine has a predetermined amount of time it must warm up within. LOL
Take good care of yourself and please feel free to come back anytime you have questions in the future. You are always welcome here.
Nov 12, 2020 at 6:46 PM
