Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Dakota
Trouble Codes
P Codes (Powertrain)
P0100 - P0199
P0120
P0120 code
1998 DODGE DAKOTA
150,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
STARLORD1976
MEMBER
FOLLOW
I keep getting a p0120 code. what is this and how to fix it?
Sep 24, 2019 at 10:24 AM
CERTIFIED EXPERT
Good afternoon,
Can you verify the code? There is no 120 listed.
Sep 24, 2019 at 11:10 AM
STARLORD1976
MEMBER
P0121.
Sep 24, 2019 at 11:14 AM
CERTIFIED EXPERT
Okay, this is for the TPS sensor voltage too low.
I attached the flow chart for you to follow to determine the failure.
Sep 24, 2019 at 12:07 PM
STARLORD1976
MEMBER
What does that mean a short in a wire or bad sensor?
Sep 24, 2019 at 12:11 PM
CERTIFIED EXPERT
A short is 2 wires touching together that should not be touching.
A bad sensor is one of the sensors not registering correctly due to an internal failure.
Sep 24, 2019 at 12:14 PM
STARLORD1976
MEMBER
What does it mean if TPS voltage is too low then?
Sep 24, 2019 at 12:17 PM
CERTIFIED EXPERT
The reading is not correct. that's why you need to follow the flow chart.
Sep 24, 2019 at 12:25 PM
