Was driving then all of a sudden, I noticed my slippery when wet light came on and stayed on would not shut off even if I pushed it. I came to a complete stop then I noticed my temperature gauge pin went from mid temperature and then shot all the way down to cool temperature. While not accelerating and sitting in idle at the light my A/C then went from blowing cool air to blowing warm air. Then when I drove off, temperature needle went back to middle temp and A/C started to blow cool air again. No over heating signs. Slippery when wet sign goes on and off while accelerating. Then on the drive back home the check engine light came on, car drove normal. Did a diagnostic reading and code P0117 came up as the only code. I had a brand new water pump, and radiator installed last month. I do not know how to fix this problem. Need some advice.
Sep 23, 2018 at 9:32 PM
