Code P0108, where is the MAF sensor located?
2019 NISSAN ROGUE
111,111 MILES • 6 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
Hello, there is a code of P0108 on the ECU that triggers the check engine light. I have tried to look for the MAF sensor, but I can't find it. What could be the cause?
Although the vehicle is Nissan Qua.
Apr 7, 2025 at 12:03 PM
BLESSING EWOBOR
  • 754 POSTS
Whenever the code is been erase with the scan tool, it will display immediately once the engine is running. The vehicle is Nissan Qashqai
Apr 7, 2025 at 4:35 PM
This is a sign the MAF sensor has gone bad. Here is the location of the MAF sensor which is near the brake master cylinder. Check out the images (below). Let us know if you need anything else.
Apr 8, 2025 at 10:14 AM
BLESSING EWOBOR
  • 754 POSTS
Thank you so much, however the code was indicating MAP not MAF.
P0108 Code: Manifold Absolute Pressure/Barometric Pressure High.
Apr 8, 2025 at 10:37 AM
The Nissan Rouge doe not have a MAP sensor. I don't have info on the Nissan Qashqai, sorry. The MAP should be on the intake manifold. If you upload images I can identify it for you.
Apr 9, 2025 at 9:54 AM
BLESSING EWOBOR
  • 754 POSTS
I saw one sensor close to the radiator, with three terminals. I measured the voltage at the sensor connector while the engine is running. With the sensor detached, the first pin was 5v, second pin was 13.5v, third pin was 0.1v (ground).
Could it be the sensor?
Apr 10, 2025 at 12:06 PM
I see the vacuum hose going to it, does it connect to engine vacuum? If so, this can be the MAP sensor.
Apr 11, 2025 at 10:02 AM
BLESSING EWOBOR
  • 754 POSTS
That is the way it has been, it is not connected to anything.
Apr 12, 2025 at 8:04 AM
I would think is should be connected to engine main vacuum. Is there an open vacuum port on the engine with nothing on it?
Apr 13, 2025 at 9:49 AM
BLESSING EWOBOR
  • 754 POSTS
If you look at the sensor, a small rubber hose is attached to it. The hose is not connected with anything.
Apr 13, 2025 at 10:51 AM
Yes, I got that, I was hoping you could look around the engine intake to see if you can find an open vacuum port it should be plugged into?
Apr 14, 2025 at 9:19 AM
