I've been told the MAP sensor is either tied into the EGR valve or the fuel pressure regulator. I have a slightly erratic idle, poor mpg, and slower than normal acceleration. I have a P71 ex police car and I run flex fuel. I can read all codes in detail with foreman. I'm rich on bank 2 trim, and I can't seem to find the MAP sensor. I've checked vacuum lines but would also appreciate a diagram of the engine vacuum lines to make sure they're routed properly. My MAP voltage is 4.9-5v which I believe to be appropriate.
Jun 3, 2023 at 5:32 PM
