Both of these codes are related to the heated oxygen sensors. Now, you mentioned that you replaced the sensors. Were they all replaced? Here is a list of possible causes:
POSSIBLE CAUSES
- O2 sensor heater operation
- O2 heater element
- O2 heater ground circuit open
- O2 sensor
- O2 heater control shorted to voltage
- O2 heater control circuit open
- PCM
I have flow charts for each code. I am going to provide flow charts from both. The attached pics are the actual flow charts. The following correlates with the pics.
________________________________
2004 Dodge SRT-4 L4-2.4L Turbo VIN S
P0038
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0038
P0038
Test 1
pic 1
Test 2 - 5
pic 2
Test 6 - 7
pic 3
SYMPTOM
P0038-02 SENSOR 1/2 HEATER CIRCUIT HIGH
TEST NOTE
This symptom is diagnosed using the test P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH.
WHEN MONITORED
Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is off.
SET CONDITION
The O2 heater voltage is out of range high. One trip fault.
POSSIBLE CAUSES
- O2 heater element
- O2 sensor
- PCM
P0032
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0032
P0032
Test 1
pic 4
Test 2 - 5
pic 5
Test 6 - 7
pic 6
SYMPTOM
P0032-02 SENSOR 1/1 HEATER CIRCUIT HIGH
WHEN MONITORED
SET CONDITION
POSSIBLE CAUSES
- O2 heater element
- O2 sensor
- PCM
________________________________________
Let me know if this helps or if you have other questions. Also, let me know if there are additional codes.
Mar 27, 2020 at 6:45 PM
