P0031 Heated oxygen sensor (HO2S) 1 Bank 1 heater voltage low
2005 RENAULT SCENIC
120,000 MILES • 8.3L • 4 CYL • 2WD • MANUAL
ADISON CANGA
I have a car that works with petrol and gas. When I start the engine i get this alarm "heated oxygen sensor (HO2S) 1 Bank 1 - heater voltage low ". I reset the alarm with OBDII program and the alarm disappear and i can work with gas, but when i turn off the car and start again the alarm come again and i cannot work with gas any more only with petrol. Sometimes when i work in gas after alarm reset the car need too much gas to run because it turn off. I have also changed the sensor of HO2S but still the same.
Can you give me advise what can I do with this?
I have control the gas electrical packet and I have make some proves and than I heard something inside of gas packet like a burn noise. Now I can't work in gas any more and the level of gas is not anymore displayed in car display. What has happened?
I have change the air-fuel rate sensor. Should I change the sensor to the catalytic too?
Thank you.
Jul 5, 2017 at 1:50 AM
Your oxygen sensor has gone out for the first sensor on the #1 cylinder. Here is a guide that will help you get the problem fixed. This is an easy repair
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Jul 7, 2017 at 2:01 PM
