Good afternoon.
The code is about the exhaust cam sensor coorelation with the crank sensor is not correct. this is not an indication of a failed part. it is a mechanical issue.
It could be dirt in the oil causing the VVT to not work or be stuck in one position.
It could be a timing chain but I doubt it as there would be more codes.
Have you tried changing the oil and filter?
* Inspect the engine for any recent engine mechanical repairs. An incorrectly installed camshaft, camshaft actuator, camshaft sensor, crankshaft sensor, or timing chain can cause this DTC to set.
* An actuator that is in the full advance or retard position can cause this DTC to set.
* The presence of DTCs P0008 and P0009 along with P0016, P0017, P0018, and P0019 indicates a possible condition with the primary timing chain and the alignment between both intermediate sprockets and the crankshaft. Or, the crankshaft reluctor wheel has moved and is no longer referenced to top dead center (TDC).
* Observe the scan tool CMP Desired, Actual, and Angle Variance parameters before a DTC sets. This may help to isolate whether a condition is specific to one camshaft, one bank, or caused by a condition with the primary crankshaft timing.
Mar 25, 2018 at 3:38 PM
