i was told by a mechanic the car had the check engine light for something simple, that i could drive the car and it will remove itself. I've driven the car almost 1,000 miles after that and the car drives fine sure it doesn't sound good after drives so i got it checked by 2 mechanics after that and i was told i need a new motor. Is that really what i need because the car drive good no hesitation it gets to speed? Not sure what i should do, is it a simple fix or do i really need a new motor? Forgot to mention when starting the car, it has like a longer crank as in like a 5 second crank to start. The car doesn't only have those 2 codes but also a couple more p001885, P042000, and p224085.
May 25, 2023 at 7:33 AM
