Code P0016, bank 1 sensor A?
2014 CHEVROLET MALIBU
137,000 MILES • 2.5L • 4 CYL • 2WD
EBERTAG
  • 19 POSTS
So, I got this code a couple weeks ago. I understand what it means… I got an oil change then light went off for a week, thought the oil change solved the problem but then came on for a day and then off again. The car runs and sounds fine. I guess my question is if it was the timing chain, wouldn’t the light stay on as it is out of time every time? I’m just confused as to why the light goes on and off with no issue driving. I’m getting it checked on the second, so I just want some thoughts. I’m just praying it’s not a loose timing chain.
Sep 27, 2023 at 12:34 AM
AL514
  • 5,464 POSTS
Hello, there are a few things that can cause this code, Ill post some service info for you. But the ECM is seeing the intake camshaft is advanced more than 9 degrees when it shouldn't be. So, something like an intake cam actuator solenoid that is sticking on, or there could be a broken pin that holds the cam actuator, and the camshaft gear is jumping back and forth, possibly getting stuck in an advanced position sometimes. But Ill post some more info on these type codes for you.
Do you have your own scan tool that can read live engine data?
And how often do you change your oil? You could actually pull out the cam actuator solenoid and check to see if its screen has any build up or oil gunk stuck in it.
Sep 27, 2023 at 8:04 AM
EBERTAG
  • 19 POSTS
Thanks for your thoughts.
Sep 27, 2023 at 10:02 AM
EBERTAG
  • 19 POSTS
I’m not a mechanic. Just wondering if I should be applying for loans for a new chain. I was overdue for my last oil change. Also wondering if the type of oil could do this. They’ve put in 5w30 0w20 . Mine is supposed to have 5w20. My mechanic seems to think it’s a dirty solenoid as well as he said the car sounds great.
Sep 27, 2023 at 10:07 AM
AL514
  • 5,464 POSTS
You are due for a timing chain/belt service, but just start saving up for that, I think this is more of the solenoid sticking, because it's happening intermittently, if you had loose a timing due to broken chain guides or chain tensioner you would most likely have a code for the exhaust camshaft as well, plus there are other timing codes that can come up. I'll take a look at the setup you have and look up the oil type, synthetic oil is best to run, but costs more. The actuator solenoids have small screens in them that are for filtering the oil entering the solenoid so they don't get stuck, but these solenoids do wear out like everything else, So I wouldn't over worry right now, have them look at it. They will check the wiring to the solenoid as well. I'll post some info here for you shortly on the oil. Loose timing chains will cause all kinds of symptoms, cylinder misfire codes, rough running, etc.
This is the recommended oil specs from the manufacturer. They do call for a synthetic oil. It will decrease the wear on the internal engine components. It's better to use it since you're starting to get higher mileage on the vehicle and you want it to last as long as possible. And it will if the oil and filter are changed at regular intervals.
Sep 27, 2023 at 10:26 AM
EBERTAG
  • 19 POSTS
Yes, I use synthetic oil. Thanks, you’ve been very helpful! I’ll let you know what they think.
Sep 27, 2023 at 10:44 AM
EBERTAG
  • 19 POSTS
Hello, I just wanted to let you know you were right. They said it was a clogged solenoid and as it was happening intermittently, and the car sounds fine, they don’t think it’s any issue with the chain like you said. They said if the light comes back on, they’ll investigate timing further but really didn’t see the need to change for unnecessary shop time and diagnosis and would be surprised if that happens. Thanks again for your advice. Hopefully that solves the problem.
Oct 2, 2023 at 4:29 PM
AL514
  • 5,464 POSTS
Thats good news, if the code comes back, you should just replace the solenoid, I can walk you through replacing it, so you don't have to pay for any labor charges. It's really easy to change. Just unplug the electrical connector, and take out 2 bolts, put the new solenoid in and bolt it back up. So just let us know what happens and keep the oil changed.
Oct 2, 2023 at 5:55 PM
EBERTAG
  • 19 POSTS
I’m just glad it’s not the chain but I will start to set money aside so I’m not a deer in headlights if it does go bad. They replaced the solenoid:) Thanks again
Oct 2, 2023 at 6:01 PM
AL514
  • 5,464 POSTS
Oh okay, if they replaced it then you should be good, but yes it would be wise to save up for a timing kit and labor. This vehicle has a main timing chain, and a smaller timing chain that goes from the balance shaft to the crankshaft and it is behind the main chain. The book time for replacing the main chain is about 7 hours, the OEM price listed for just the chain itself is about $74, but that it the what a shop would pay for it, they will mark that price up, but they will do a complete timing chain kit, which should come with both chains, the chain guides for each side, and the timing chain tensioner. They will need to reseal the timing cover on the front of the engine. It would also be a good idea to do the water pump while they have it apart. So, if you want to get an estimate now, you will know how much you need to save up for the job when the time comes.
This is a diagram of the timing chain components with the front engine cover off, just to give you an idea of what it looks like.
Oct 2, 2023 at 7:57 PM
EBERTAG
  • 19 POSTS
Yikes what a mess! lol Thanks for the information. I actually just had fuel and water pump replaced within the last year and a half. :)
Oct 2, 2023 at 9:50 PM
AL514
  • 5,464 POSTS
It's not actually that bad compared to some other setups, there are some models that have 2 camshafts per cylinder head, something like a V6 or V8 and then have a small chain for each pair of camshafts, and then another chain on top of those, etc. Some are real nightmares, but you're ahead of the game using synthetic oil and keeping up with the filter and oil changes. Let us know if you need any other help in the future.
Oct 3, 2023 at 7:54 AM
EBERTAG
  • 19 POSTS
So sad news. Light was back on :( he suspects bad phaser as the car is running fine. Suggested just doing the whole timing set as it’s about the same cost for just phasers $1,500 ugh, never another chevy! Fixing this and selling it.
Oct 3, 2023 at 12:00 PM
AL514
  • 5,464 POSTS
He suspects? Thats not a diagnosis though. There are a number of tests that can be done to know what the problem is. What if it's just a bad camshaft position sensor? The tests that can be done are checking the "Desired" position vs the "Actual" position of the Intake camshaft position. They can use an oscilloscope and visually see the position of the intake cam. A bad phaser will show up on a scope. Even taking off the valve cover, they would be able to move the phaser if it's broken and not in its locked position. I would hate to see them replace $1,500 in parts just to find out it's only a sensor. Or wiring to the sensor or solenoid. Thats a lot of money for them to be guessing. Sorry I just don't like to see situations like this.
Oct 4, 2023 at 2:38 PM
EBERTAG
  • 19 POSTS
Yes, last time River just replaced the solenoid and did “open up” The car. I hope they would investigate all that before changing the chain or he’ll be refunding me lol. I’ll keep you posted.
Oct 4, 2023 at 4:55 PM
EBERTAG
  • 19 POSTS
Sorry didn’t open up the car.
Oct 4, 2023 at 4:56 PM
AL514
  • 5,464 POSTS
Yeah, make sure they do the proper testing. Unless you're prepared for the timing chain job. They should be able to show you proof that the camshaft phaser is really the issue.
Oct 4, 2023 at 5:49 PM
EBERTAG
  • 19 POSTS
Okay, got the verdict. Turns out there was a loose bolt (that luckily didn’t get into the engine) and the guides were getting bad sliding back and forth hence why the light would go on and off. Just had them do the whole set so I won’t have to worry about it anymore.
Oct 23, 2023 at 4:38 PM
EBERTAG
  • 19 POSTS
Ok got the verdict. Turns out there was a loose bolt( that luckily didn’t get into the engine) and the guides were getting bad sliding back and forth hence why the light would go on and off. Just had them don the whole set so I won’t have to worry about it anymore.
AL514
  • 5,464 POSTS
Good to hear you got it taken care of. You won't have to worry about chain issues in the future now. They make all those chain guides out of plastic, and they all end up breaking at some point.
Oct 23, 2023 at 6:50 PM
EBERTAG
  • 19 POSTS
Yea, being in Wisconsin with extremely hot and cold weather (sometimes in the same week) wreaks havoc on plastic. Such inferior parts for such expensive cars. Thanks again.
Oct 23, 2023 at 7:00 PM
