P0015
2007 BMW 328
186,286 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
JACKTT
  • 5 POSTS
b camshaft position timing over retarded bank one. explanation camshaft actuator failure? probable cause mechanical timing condition?
Mar 4, 2017 at 7:22 PM
KHLOW2008
  • 41,814 POSTS
Usually is a fault with the vanos system. It could be oil pressure leakage due to bad seals or a fault with the sensor. Low oil level/pressure can cause this fault too.
Mar 5, 2017 at 8:24 AM
JACKTT
  • 5 POSTS
what sensor would be most practical?
Also one of the symptoms. I have is when I go to brake it drops rpm in second to 0 while I brake.
Also it says mechanical can that be related with electronics or your saying that electronics can cause mechanical. Timing issues.
Mar 5, 2017 at 1:51 PM
SATURNTECH9
  • 30,869 POSTS
What is the exact code number not code description?Also it could be the timing could have jumped forward and now be off and set that code.
Mar 6, 2017 at 6:45 AM
KHLOW2008
  • 41,814 POSTS
Vanos is the valve timing solenoid at front of camshaft, on cylinder head.
Mar 6, 2017 at 7:14 AM
JACKTT
  • 5 POSTS
exact code is P0015
Mar 6, 2017 at 7:30 AM
Is the engine making noise when it runs? It could be the actuator or the valve which had a problem plugging up if the oil was not changed, they have a small screen. I don't think it is the position sensor becasue you don't have the codes for that. I would try the valve first and then go from there. Clear the codes once finished.
Best, Ken
Mar 8, 2017 at 12:14 PM
JACKTT
  • 5 POSTS
no noise sir. and also i orded that valve so i will try that first. also wanted to thank all of you.
Mar 9, 2017 at 6:38 AM
Please let us know what you find so it will help others.
Best, Ken
Mar 9, 2017 at 9:45 AM
JACKTT
  • 5 POSTS
update, replaced both intake,and exhaust,solenoid vanos valves. problem solved.
Apr 5, 2017 at 11:56 PM
Nice work, we are here to help, please use 2CarPros anytime.
Best, Ken
Apr 6, 2017 at 9:48 AM
