Good afternoon.
This is a code for the cam timing actuator.
Below is a description for you to view and more information as well.
Just changing the oil would not be enough if the valve is clogged with debris. The entire oil system must be flushed to get rid of the debris and hopefully, it will start to work again.
General Description
The CVVT (Continuously Variable Valve Timing) system is installed to the chain sprocket of the exhaust camshaft. There is no variation in valve timing of the exhaust cam because the exhaust camshaft is driven by the timing belt. The timing of the intake cam is varied by the relative operation the CVVT vane to the housing. This system helps the engine decrease exhaust gases and increase engine power and fuel economy by changing the valve open/close timing of the intake camshaft.
Nov 5, 2018 at 1:57 PM
