Code P0010, check engine light on?
2011 MITSUBISHI OUTLANDER
120,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
MAHGYVER
  • 7 POSTS
Hello, I'm getting a check engine light after having the starter replaced. It was giving me extra noise after cranking it.
From what I found, the exhaust manifold for one needed to be removed to be able to access the starter.
SUV seems to be running normally, no noise, no erratic RPMs, not shutting down. Is it possible that something along the disconnect caused this? If so, will the error clear out on its own (meaning everything is good), or should I manually clear out the code and then see if it comes back?
Thank you.
Jan 27, 2025 at 12:54 PM
TOM STASSLE
  • 6 POSTS
This has nothing to do with the starter repair unless they damaged the intake oil control valve. I would clear the code with the scanner if it comes back then you will need to see if the valve has failed. I have attached the circuit here for you to see.
https://mitsubishitechinfo.com/data/GS41/2009/13/HTML/M113158140006500USA.htm
Jan 27, 2025 at 2:18 PM
TOM STASSLE
  • 6 POSTS
Hi
Thanks for the info, Tom. It is appreciated. Also, I agree with what he recommended. The code is related to the intake manifold oil control valve. Note that the code indicates a variance of engine timing by at least 5° for at least five seconds. Nothing they touched would have changed the timing.
I suspect they disconnected the battery while the work was being done, so I feel Tom has a good idea.
Have the codes cleared and see if they come back. Additionally, make sure the engine oil is clean and full.
One last thought. I am assuming this is not an Outlander Sport with the 2.0L. If it is, let us know. That changes things.
Let us know what you find.
Jan 27, 2025 at 7:08 PM
MAHGYVER
  • 7 POSTS
Wow, quick replies! Before I cleared the code, I checked and there were two more! P0442, C0700. I cleared it, turned off the car and started. A few minutes later, I got a P0004 and P0010. They did have to disconnect the battery in addition to the intake manifold. The only other thing they mentioned is that the air intact duct has a split in it that they "patched" since it can only be ordered through manufacturer. They said the split could cause engine to have erratic engine lurching (from excess air) - didn't have this issue, but maybe split wasn't big enough. Other than all the codes, the car runs pretty smoothly. I'll do more checks after your thoughts on the additional codes.
It's a small shop I go to for years, can't imagine them causing problems and not mentioning it. I don't think they like working on the Outlander though, maybe limited knowledge? They didn't have the computer necessarily to diagnose/fix when my ABS needed to be changed. I brought it to a dealership, they said ABS was bad, but it would cost a lot, I forgot, so I was able to buy a used one, replaced it myself and a friend that had a much superior OBD machine was somehow able to clear the ABS code. So that's the shop story.
Jan 29, 2025 at 6:16 AM
The P0442 indicates an EVAP leak (small leak). In this case, I would recommend having the system smoke tested. A small leak can be very difficult to locate. When smoke is injected into the EVAP system at a very low pressure, it will leak out where the leak is located.
The present code, a P0004 is likely related to an issue with the fuel volume regulator. The code indicates the regulator is not sending back the proper voltage signal to the ECM. It could be a sensor issue or a wiring issue. It would be a good idea to check the fuel pressure to confirm it is still within the manufacturer's pressure specifications. A weak pump can cause the code to be set as well. Note that oftentimes, this code will cause a decrease in fuel economy, poor performance or even stalling. I'm not sure if you noticed anything like that.
The P0010 is related to the intake engine oil control valve. This one could be tied into something that unknowingly was done by the shop. I attached a pic below showing its location. Check to make sure everything appears connected and undamaged in that area.
Now, here is where it gets interesting. The C0700 is a code that indicates an issue with the cylinder management. This can be a result of several things but usually indicates an oil pressure issue. The problem is caused by the variable cylinder management system switching on and off the code will be set when the oil pressure drops to the point where it can no longer control the VCM circuit.
It seems we have multiple things happening at the same time. We need to focus on one thing at a time, so I need to confirm if all codes have returned or if is it only P0004 and P0010. Interestingly, it could be oil pressure related according to two of the codes.
See pic below.
Jan 29, 2025 at 7:52 PM
MAHGYVER
  • 7 POSTS
Thanks for the diagram, JACOBANDNICKOLAS. I was trying to figure out if this was bird's eye view or looking at the engine (I deal best with color pics, hehehe). I removed he cover and just did some checking to see if *anything* is loose. Well, it was odd and it caught my eye. It was a hose clamp... wedged vertically! Is this the one for the hose they said is cracked? The temporarily sealed it, but didn't put back the clamp. Could that cause the issues? Consequently, I just realized my pic matched your diagram, so at least I'll now have a better idea where the intake engine control valve is. I'll check next time I'm able (somebody else drives this SUV).
Feb 4, 2025 at 5:27 AM
Sorry for the delay in getting back to you. Everyone at home is sick and this is my 3rd job. LOL
Yes, you found the component. Was the hose clamp for the part they repaired? Since you have reinstalled it, has there been any change?
If you have noticed a change, clear the codes and see if the same ones return.,
Let me know what you find.
Feb 5, 2025 at 5:33 PM
MAHGYVER
  • 7 POSTS
Hi, no problem. I'm just glad you're willing to help. I didn't put it back - it's too cold outside and I'm wanting them to do the work (I paid for it) and hope they'll be more vigilant (hopefully) in making sure everything else is good. Otherwise, it'd be what I did that could be causing the problem. Hope I won't get charged (you never know), in addition to dropping it off again and not being able to use the SUV. I'll keep you posted.
Makes me wonder how it would have ended all the way to the left side...even if was placed on top of something and then it fell, I would likely put it on the right side of the engine bay. Unless the mechanic is left-handed...
Feb 5, 2025 at 8:12 PM
JACOBANDNICKOLAS is on of our best, please let us now what happens.
Feb 8, 2025 at 9:59 AM
MAHGYVER
  • 7 POSTS
Finally got the clamp back in, and was told they didn't see any other issue. Oil was low (driver did see a quick low oil pressure once), which caused gurgling(?) causing the oil control valve error. I assumed they filled it back up which I guess I should check myself, since the p0004 and p0010 codes are back. One common fix is oil change, which it's due soon. It's too cold outside. I will try to check further connection. Weird about low oil is that it didn't look like there was any leak on the driveway. I don't necessarily smell burning oil or see blue exhaust smoke...
Feb 19, 2025 at 6:44 AM
Yes, the engine needs fresh oil and filter for the camshaft actuators to work correctly, especially when the engine gets a few miles on it.
Code P0004 - Fuel Volume Regulator Control Circuit High
Code P0010 - "A" Camshaft Position Actuator Circuit (Bank 1)
So, these will be two problems, please start a new thread for the p0004 we will continue. I would change the oil and then clear the codes to see if the p0010 code goes away.
Feb 20, 2025 at 9:25 AM
MAHGYVER
  • 7 POSTS
I have to sad I'm happy, sad and frustrated about all these. Happy because it's finally done. Sad because I have to stop going to this mom-and-pop shop. I considered writing a review online, but that can do a lot of damage. I will write them a letter instead detailing the events. Frustrated cause I tried to give them the business, and even after getting codes, doing my research since I didn't want it to be another cliche, then pointing out the clamp that was not put back, and mentioning that luckily nobody got hurt, after finally getting an oil change (and that they cleared the codes), after all those different days of not being able to use the SUV... there were still codes!!!
I'm not good with parts names and locations, but point me to a real pic (drawing is hard to interpret sometimes, especially if already zoned in to an area without another drawing of the big picture for reference), and give instructions, I can get it done. Anyway, I just figured I needed to address the Oil Control Valve part. But guess what? I saw the unclamped air intake hose... still unclamp (I simply trusted that they put it back cause you know, it was a couple minutes job, but that I was hoping they check more regarding the errors)! I was appalled and livid. I also found the other end had a crack, and after a 2 minute search, found and ordered the part that they said was hard to find. I temporarily patched the crack with electrical tape, like they did, put a clamp and cleared the codes!
Seemed to work ok (never really had obvious operational problem other than codes), then codes came back! I went and figured I need to check the Oil Control Valve.... but guess what? I saw the CPS sensor wires. Not even connected! There were no words... I put it back how it seemed to go logically and cleared the codes. Guess what? No more codes!
I also got the new intake hose and while replacing it, noticed a few hoses not pushed back all the way or not even clamped back. Those hoses are in enough to not cause issues, but come on, the bare metal is an obvious tell about its previous position.
Mar 31, 2025 at 8:52 AM
Good find on that, maybe the shop was just having a bad day, it happens. Thanks for sharing the fix, am i sure it will help others. Please use 2CarPros anytime we are here to help.
Mar 31, 2025 at 12:16 PM
MAHGYVER
  • 7 POSTS
I guess it's counted a day for each and every time I went there....
If something really bad happened, I hope the judge won't accept that the defendant was having a bad day.
Thanks for all your help. It's websites like this that helps people have like a second opinion.
Mar 31, 2025 at 1:44 PM
