Welcome back:
Well, at this point, I would replace the sensors and pray that takes care of the issue. If it doesn't, chances are we will need to check the timing chain.
That is where I question how this is sensor related. The code just indicates bank one. There is a sensor for both the intake and exhaust cam. When there is one sensor which is bad, the code is usually different and indicates which sensor is the cause. With this code, it is more likely that both intake and exhaust are equally off indicating a chain issue.
Anyway, those are my thoughts at this point. Let me know which direction you want to go so I can help you. I wish I could give you a more definitive answer.
Oct 30, 2019 at 6:07 PM
