Was having problems with the pass lock security over winter. Was told if I can get it to start and remove the pass lock module with it running that it would permanently delete the system. Fast forward to now. The alternator went out causing the fuel pump to run the battery down and stall. I replaced the alternator charged battery and now when I go to start it, it runs for a second and does. Cuts fuel supply. Has a code p1626 fuel enable theft code. What do i do to finish off disabling this system? Is an old work truck don't need though I was done with this. There is no module in it.
May 22, 2022 at 11:37 AM
