Both of those codes are for the O2 sensor heater circuit, not for faulty sensors. More than likely there is a broken wire or bad connection in the wiring before it gets to the sensor connectors. The code that went away was probably because the wire break was between the sensor and connector.
To test is simple, disconnect the sensor, connect a test light to the two wires that power the heater and activate the heater circuit. Then follow the wires back to the bad connector or broken wire.
May 20, 2017 at 9:20 AM
