How to test the Oxygen sensor?
2006 PONTIAC GRAND PRIX
172,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
PINEAPPLEAK90
  • 6 POSTS
How to test if the oxygen sensor is bad?
Jun 13, 2022 at 12:27 PM
SQM
  • 6,383 POSTS
The oxygen sensor can be tested by observing the voltage fluctuation.
You will need to use a voltmeter to get started. It will require you to start the vehicle for about 15 minutes for everything to go to operating temperature. Then use the voltmeter to measure the voltage.
Here is a helpful guide that explains exactly what needs to be done:
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Let me know of any questions.
Thank you.
Jun 13, 2022 at 2:49 PM
