Welcome back:
Do you at least hear a click? Are you sure the battery is okay?
If the battery is good and there is not even a click from the starter, I need you to check if the starter is getting power. Here is a link that shows how. Basically, on the starter one big wire comes direct from the battery and is hot all the time. There is a smaller wire that should only get power when the key is in the start position. I need to know if both have power.
https://www.2carpros.com/articles/starter-not-working-repair
If you do hear a click and know the battery is good, we need to make sure the engine isn't locked. You may have blown a head gasket due to heat and one of the cylinders could even be full of coolant preventing the engine from turning.
Aug 10, 2019 at 9:41 PM
