Overheats while accelerating
2008 PONTIAC G6
200,104 MILES • 6 CYL • 2WD • AUTOMATIC
ANGIE BACOME
Car overheats while accelerating and driving. When I come to a stop sign or stop light, the temperature goes down. I don't hear any engine noise or see any leaks. Also noticed the heat is warm but not hot.
Nov 10, 2020 at 4:56 AM
Interestingly, when driving at a maintained speed, the engine should run its coolest simply because there is a continuation of airflow through the radiator just because the vehicle is moving.
Tell me, have you noticed any coolant leaks? Is the coolant level full? Also, have you noticed any white smoke or creamy substance mixing with the engine oil?
Here is a link that I want you to look through. It explains how to check for a bad head gasket. I'm not suggesting that is the problem, but I want you to check a few of the simple things listed. For example, is there white smoke from the exhaust? Also, the link shows what oil looks like when contaminated with engine coolant.
However, before you do this, simply make sure the coolant level isn't low. That can cause this problem as well. (specifically the heat issue).
Here is a link that explains how a cooling system works. I thought it may be of interest to you.
https://www.2carpros.com/articles/engine-cooling-system
Let me know if you are able to find anything that I mentioned. Also, please feel free to ask questions if you have them.
Nov 10, 2020 at 12:03 PM
