Hi Team,
Have changed timing belt, water pump, radiator, coolant, thermostat, engine oil (5W30). Fluids have good levels.
No water in the engine oil nor oil into the coolant reservoir tank.
Car is working normally. No power loss at all.
Current outside Max Temp 35C.
Temperature running normally and as soon as switch on the A/C temperature goes up til reaching the red mark.
Same scenario when turning on inside heater.
By the when turning on the A/C, cooling fan is working too. Not sure about 2nd speed? Don't know how to test.
A/C is blowing cold air.
Fuse for cond 1 and cond 2 are okay.
Any lights on this issue?
Thank you.
Wishing you a nice day.
Best regards,
Gilles
Thank you.
Best regards,
Gilles
Jan 13, 2020 at 4:24 AM
