Overheating still
2003 INFINITI G35
130,000 MILES • V6 • 2WD • AUTOMATIC
STEPHP9034
Okay, my mechanic changed the thermostat, radiator, water pump and can't find any leaks either. can any body tell me why it keeps overheating?
May 11, 2020 at 4:30 PM
When does this overheat? Sitting at idle or at highway speeds? Also, can you let the vehicle start to get hot and see if the fans come on? They should come on around 195 degrees so if they are not coming on then we need to look into this.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Let me know about this and we can go from there. Thanks
May 11, 2020 at 5:23 PM
STEPHP9034
Well at the moment I can't say because my mechanic has had my car for already 2 weeks trying to figure it out, but again every thing is new and the burp it out really good. I know the tune not the issue but I all go those changed and the temperature sensors also new. the check the gasket as well and that not it. can there be another issue?
May 11, 2020 at 5:27 PM
Okay. We need them to make sure the fans are operating properly. If they are not then they will be chasing their tail for longer. If the fans are not cooling the coolant in the radiator then it will continue to overheat.
Let us know what happens with this one and what they say about the fans. Thanks
May 11, 2020 at 8:07 PM
STEPHP9034
Okay, thank very much. I will see what they say I'll be talking with them tomorrow afternoon to see where we at.
May 11, 2020 at 8:12 PM
Okay. Great. We will wait to hear back. Thanks
May 12, 2020 at 8:41 AM
