Overheating issued
2003 OLDSMOBILE SILHOUETTE
218,000 MILES • 6 CYL • AUTOMATIC
BIGROE
Van keeps overheating. Had mechanic to flush radiator/engine and changed hoses. Still the same problem. Van used Dex coolant but turns rusty and a Little thick. Any suggestions on what it could be? Please help me.
Feb 9, 2017 at 7:03 AM
HMAC300
  • 48,601 POSTS
have it pressure checked for leaks may be ahead gasket. If Dex cool does not get filled enough and get air it will clog passages in block and head. I am assuming everything has been checked in rest of system.
Feb 9, 2017 at 7:09 AM
BIGROE
It did this last year but this one mechanic did let air out from somewhere and it did fine up until now. Problem went away for a year.
Feb 9, 2017 at 7:12 AM
HMAC300
  • 48,601 POSTS
F pressure check does not show anything when engine is warm/hot with engine off disconnect fans so they wont start and feel radiator in several places with hand. if you feel any cold spots the radiator is not good and needs replacing. it should feel warm all over.
Feb 9, 2017 at 8:03 AM
BIGROE
HMAC300 thank you! I will let you know my findings.
Feb 9, 2017 at 8:43 AM
