overheating, high idle
1997 TOYOTA 4RUNNER
136,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
MARLA CHOI
what should my idle be when cold? my idle is high 1900 rpm if I adjust it correctly will that stop my car from overheating?
Dec 26, 2016 at 8:57 PM
STEVE W.
  • 15,113 POSTS
No, high idle should not lead to an overheat. It sounds more like you have a vacuum leak that is causing the high idle. Check for cracked/broken vacuum lines first. If you do not find any clean the IAC valve and the throttle body.
Dec 27, 2016 at 1:06 AM
