Overheating even when idling?
2016 CHEVROLET TRAVERSE
168,000 MILES • 6 CYL • 4WD • AUTOMATIC
TLUCAS86
Engine fans are always running for a while after shutting off and now is overheating even when in idle. No codes are coming back with computer check. I hear a gurgling from the coolant after shutting off the car and the large hose is hot from the coolant to engine. I think its either a clogged hose or the thermostat...how could i be sure without a full service diagnosis??
Jul 29, 2022 at 10:36 AM
SQM
  • 6,383 POSTS
Typically, when the thermostat is stuck closed, it won't allow coolant to flow, and you will have a significant temperature difference between the upper and lower radiator hose. One will be hot and stiff and the other will be cooler and softer.
Take a look at this guide. It goes over the troubleshooting steps for overheating.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Let me know what you find or if you have any questions.
Thank you.
Jul 29, 2022 at 4:11 PM
