overheating coolant tank
2001 CHEVROLET CAVALIER
19,500 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
LINDA VAN ELSWYK
It has happened everytime i take off my coolant cap to check coolant level. the car heats up even after i add coolant. i make sure the cap is on tight. there are no signs that there is a leak until yesterday when i looked, the low fluid light went on. but there were, once again, no signs of leakage, at least while i was parked. what next?
Apr 15, 2019 at 9:42 AM
Good afternoon,
It is possible the thermostat is bad causing it to run hot. It will also expel coolant out the tank.
I would start by replacing the thermostat.
Do the cooling fans work?
Removal Procedure
1. Drain the cooling system.
2. Remove the lower radiator hose from thermostat outlet.
3. Remove the thermostat outlet bolts and outlet.
4. Remove the thermostat.
5. Clean the mating surfaces of the radiator outlet and the radiator outlet pip
Apr 15, 2019 at 10:36 AM
