Overheating, expansion tank had a crack and no coolant, So i replaced the expansion tank and filled the car with coolant. The temperature gauge goes from 195 up to almost the red mark, then goes down and back up randomly, either when driving or at idle. I think there might be air in the radiator or maybe it is the water pump. The heater does get hot. Some times very hot. It also squeaks when i am driving and gets faster squeak when i accelerate, squeaks when idle sometimes too. I do not think the squeaking is the brake. It is either the idle pulley bearing or water pump. Your thoughts? Thank you.
Apr 11, 2017 at 11:53 AM
